 Deleting Registry Keys from the Command Line
PostSubject: Deleting Registry Keys from the Command Line   Wed Aug 01, 2007 3:49 pm
There are two ways to delete a key from the Registry from the Command line. At the Windows Command line:
RegEdit /l location of System.dat /R location of User.dat /D Registry key to delete
You cannot be in Windows at the time you use this switch.
Or you can create a reg file as such:
REGEDIT4
[-HKEY_LOCAL_MACHINE\the key you want to delete]
Note the negative sign just behind the[
Then at the Command line type:
1. RegEdit C:\Windows\(name of the regfile).
» Line Break not working (HTML)
» Transparent and semi transparent body line background color
» Drop down list separator line
» Line Breaks
» How can I remove this line under the navbar?
